Group: DynoMotion Message: 1016 From: vetsen@rocketmail.com Date: 4/3/2011
Subject: AC servo compatibility (newbie)
I have a number of Tamagawa servos/motors and I don't know how to incorporate them into my new project.
I am familiar with steppers and have successfully built a few small machines with them.
Can anyone give me a basic overview of what I need to know to determine how to drive this system? AC servos are new to me, and I need some direction.
Tamagawa AU6550 series http://www.tamagawa-seiki.co.jp/pdfe/1525n4e.pdf
scroll down to page 8-9
Any help would be great,
Thank you,
Vetsen
Group: DynoMotion Message: 1017 From: Tom Kerekes Date: 4/3/2011
Subject: Re: AC servo compatibility (newbie)
Hi Vetsen,
It looks like you basically have two options to use that motor drive with our KFlop Controller.  Either command the motor driver open loop with Step + Direction signals much like a Stepper Driver (a footnote seems to indicate it accepts Step + Direction as well as CW and CCW pulses)..  Or command the driver with a +/-10V Analog velocity command and feed the encoder signals back to our KFLOP+Kanalog boards and have KFLOP close the position loop.  My preference would be the second choice where our software and diagnostics could be used to tune and monitor the servo performance.  It looks like the encoder signals would need to be paralleled to both the Servo drive and our Kanalog board as the position information is needed for both.
I hope this helps.
Group: DynoMotion Message: 1018 From: vetsen@rocketmail.com Date: 4/3/2011
So are the signals of my servo amp and the motor standard?
Would it make any sense to buy new servo amps.? I guess what I am trying to say is: what is the likelihood that this would work with the kflop?
Thanks for your prompt response.
Vetsen
> Hi Vetsen,
> I hope this helps.
> From: "vetsen@..." <vetsen@...>
> Sent: Sun, April 3, 2011 2:25:31 PM
> Subject: [DynoMotion] AC servo compatibility (newbie)
> with them.
> Thank you,
> Vetsen
Group: DynoMotion Message: 1019 From: Tom Kerekes Date: 4/3/2011
Hi Vetsen,
Yes +/- 10V analog signals are very common and standard.  As are the differential encoder signals going from the motor to the drive.  It is very likely to work with KFlop+Kanalog.  But the document you supplied on the amps does not provide details on how to configure the various modes.   You would need to research it further.  To test if the Amp is configured correctly you could apply a small voltage to the input.  Possibly even a 1.5V battery.  The motor should run at a controlled speed of 15% of full speed.  Reversing the battery to apply a negative voltage should cause the direction to reverse.  If that works it would almost certainly work with KFlop+Kanalog.
